BJT and LOW frequency response of CE amplifier
Discussion in 'Homework Help' started by ador, Oct 21, 2005.
  1. ador
    Oct 13, 2005
    can you help how to know the BJT configuration by testing it and connecting a circuit on it??? and about the CE amplifier, what is about the low frequency response???
  2. mozikluv
    Jan 22, 2004
    1,437
    hi ador,
    can you expound further on your question? it's so vague. there are lots of bjt configurations. are you referring to identifying a bjt configuration on a certain circuit and ways on how to test it?
    as to frequency response, it will depend on the kind of bjt you will use and other parts that you connect to it and it's connection to the other stage.
    have you check the bjt tutorial in this site?
    moz
  3. Overclocked2300
    Apr 24, 2005
    124
    Common Emitter is probably the most common configuration. Freq response is controlled by the Coupling Capacitor and Bypass Cap.
    But then, it also depends if you have a tank circuit too, then that would alter freq response.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With respect to the low frequency part of your question - any common-emitter BJT setup will work right down to DC with no problem. That's a nice case, too, because phase shift is exactly 180 deg., and measuring things like base and collector currents is quite easy.
