BJT Amplifiers question
Discussion in 'Homework Help' started by Digit0001, Sep 24, 2011.
  1. Digit0001
    Mar 28, 2010
    89
    Hi
    The following question can someone explain the first section where they changed the original circuit into thevinin's equivalent. However can someone explain to be what the answers have done?
    View attachment question7.doc
    This is what i have done:
    i have changed to thevinin's equivalent and then got stuck because i did not know the values of R1 and R2.
    Another question when do we use the resistance reflection rule? Is it only used in a emitter resistance amplifier circuit.
    P.S
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The answer seems to be applying a 'rule of thumb' that sets the voltage divider bias network thevenin equivalent resistance to ~10% of the effective DC resistance looking into the base.
  3. Digit0001
    Mar 28, 2010
    89
    can anyone answer my second question?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    What is your second question?
  5. Digit0001
    Mar 28, 2010
    89
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    what do you mean by "resistance reflection rule".
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    From the context of the question, I suspect that the "reflection rule" referred to here is the reflection of the emitter resistance into the base circuitry.
    If my assumption is correct then my answer to that question would be that the "reflection rule" is always applied. Bear in mind that there is an intrinsic emitter resistance that is defined by the equation 0.026/Ie. This resistance is usually so small that when a physical emitter resistor is included, the intrinsic emitter resistance can be conveniently ignored.
    hgmjr
  8. Digit0001
    Mar 28, 2010
    89
    ok thanks for the help
