BJT amplifier
Discussion in 'Homework Help' started by full, Oct 18, 2014.
  1. full
    May 3, 2014
    225
    hello everyone,
    I do this problem in basic common emitter Bipolar junction transistor (BJT) amplifier ........
    me solution true? or there are some wrong?
  2. full
    May 3, 2014
    225
    why some time in Bipolar junction transistor the Ie=(1+B)Ib & Ie=BIb ?
    thanks,
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well you made a mistake R1 is 250k not 225K. Because Vth = 1.1538V not 1.25V.
    Ib = 3.48329μA; Ic = 417.995μA; Ie = 421.478μA.
    As for the gain
    Av = Rc/(re + RE) * (Rib||Rth)/(Rs + Rib||Rth) = 8.46 * 0.985 =8.3V/V
    re = 26mV/Ic
    Rib = ( β+1 )*(re + RE) = 80kΩ
    Rth = R1||R2 = 57.7kΩ
    And for BJT we have Ie = Ib + Ic but as you know Ic = Ib*β. So we have Ie = Ib + β*Ib = (β +1)*Ib.
  4. full
    May 3, 2014
    225
    thanks sir,
    when current collector equal current emitter (Ic=Ie)?
  5. shteii01
    Feb 19, 2010
    3,518
    515
    I guess when transistor is in Cutoff region.
  6. full
    May 3, 2014
    225
    thanks sir,
    is mean there isn't resistor and source in emitter region?
  7. shteii01
    Feb 19, 2010
    3,518
    515
    In Cutoff Ic=0, Ib=0, therefore Ie=Ic+Ib=0. Therefore Ic=Ie=0.
  8. full
    May 3, 2014
    225
    obs:eek:
    see this ie=ic why?
    thanks sir,
  9. shteii01
    Feb 19, 2010
    3,518
    515
    Ib can be VERY small. So. It becomes a question of precision. How precise do you want to be?
    full likes this.
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    The emitter current is always equal to Ib + Ic. But because the beta value is large we can ignore the base current and say that Ie = Ic.
    For example if β = 100 and Ib = 10μA we have Ic = 100 * 10μA = 1mA and Ie = Ib + Ic = 1.01mA
    So we don't do the big mistake/error if we ignore the Ib current and say that Ie = Ic = 1mA
    full and Random3s like this.
  11. full
    May 3, 2014
    225
    I do another problem ,but this is difficult :confused:
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    Your DC current calculation are totally wrong.
    Vth is ok and Rth also. But your KVL loop (Vth - VRB - Vbe - VRe = 0) is wrong.
    You forget about Vee in your loop.
  13. full
    May 3, 2014
    225
    if I do KVL loop (Vth - VRB - Vbe - VRe +VEE= 0) true?
    thanks sir
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    No, wrong again.
  15. full
    May 3, 2014
    225
    ok , If I do KVL loop (-Vth - VRB - Vbe - VRe +VEE= 0)
    but the loop flowing from -Vth+ is mean positive in voltage true?
    about Av= (B Rc)/(r-bi +(1+B)Re) *Ri true?
    thanks sir
  16. Jony130
    Feb 17, 2009
    3,993
    1,116
    In PNP transistor current flow from +Vee--->Re--->emitter-base junction--->Rth--->Vth--->-Vee
    Because for PNP Ie current is also equal to Ie = Ib + Ic
    So we start at the bottom of a Vee and we go from - to + so we give + sign.
    Vee - VRe - Veb - VRth - Vth = 0V
    Vee - Ie * Re - Veb - Ib*Rth - Vth = 0
    Ib = Ie/(Hfe +1) therefore
    Vee - Ie * Re - Veb - Ie/(Hfe +1) *Rth - Vth = 0
    Ie = (Vee - Vht - Veb)/( Rth/(Hfe +1) + Re ) = (12 - 10.2 - 0.7)/(12.75/100 + 0.5) = 1.75mA
    Ri ?? And where is RL ?
    full likes this.
  17. full
    May 3, 2014
    225
    thanks sir:):)
    Ri =(Rth//r-bi)
    I forget RL sorry ,
    Av= (B Rc//Rl)/(r-bi +(1+B)Re) *Ri
  18. Jony130
    Feb 17, 2009
    3,993
    1,116
    But in this circuit we don't have source resistance? So how can Rht has any effect on voltage gain ?
    For me the voltage gain is equal to
    Av = Rc||RL/(re + RE) = (β * Rc||RL)/(Rpi + (β+1)*Re) ≈ 2.6V/V
    full likes this.
  19. full
    May 3, 2014
    225
    thanks sir ,you are great man...... :)
  20. full
    May 3, 2014
    225
    I do this problem but in common collector :
    I think there is wrong in Ac analysis ...
    thanks,
