Indeed, but it's still a little hard to me to understand your method at the first time I have contact with it! I need to look to it several times before I can get into your mind and understand it the way you do!But we do not have to do that
Ix = Vx/Rx + hfe*Vx/Rx + Vx/Re = ((Re + hfe*Re + Rx)*Vx)/(Re1*Rx) ---->Ro = (Re1*Rx)/(Re + hfe*Re + Rx) = (Re1*Rx)/(( hfe+1)*Re + Rx)
But for me this expression is too complicated and this is why I omitted Re and find Rx/(hfe+1) and finally Ro = Re||(Rx/(β+1)). And this equation looks more pleasant don't you think so ?
Because now we can solve for Vx/Ix directlyBut what was the point on writing Ix as:
Ix = Vx/Rx*(hfe + 1) ???
Do not bother about Rt it is only an auxiliary variable.Also at your post #17 you introduce a new parameter, Rt. What is this Rt?
Yes, for sure you can use the same method for finding Ro that you have been using for finding Rin. And good luck this, "high entropy expression" guaranteed.For instance, for Vi, we have wrote an equation of a closed loop (or net) that included voltage drop at hie and the voltage drop at Re//R_Load, right?
For Ro, we replaced R_Load by a voltage source Vx and we also shorted Vsig. From here, can I try to write an equation as we did for Vin? An equation of a closed loop (or net) that includes the voltage drop at Re, the voltage drop at hie and the voltage drop at Rb1//Rb2???
I saw that you have been including somehow Rsig, but we have not done any example in classes including Rsig. We have only included Rsig on some cases for Ro, not for Vi or Vo or Ri or input or output currents.Also I want to point out that your voltage gain expression do not show/cover the hole story. What about Rsig ?? Rsig also have a big influence on the voltage gain.
