I attached a picture of how to set up a voltage divider. Use Rb of 10K ohms and Ra of 1K ohm for division by 10. This should make your generator signal 12.5 mV. But use Rb 100k and Ra 1k for adjustability. This divider is standard lab practice. (On edit: Oops I forgot the line between the base and the node at R1 and R2. It's the same as your circuit.)
As pointed out by everyone above, you need a small signal at the input to avoid the type of distortion you've been getting. I'll tell you more about this if you want. For now just make that divider and you should get rid of your distortion. Be sure not to turn the overall input voltage up past 10 mV. This means your output voltage will be smaller than you've been looking at, but at least it won't be distorted.
