BJT amplifier circuit
Discussion in 'Homework Help' started by curriejohn, Jun 16, 2015.
  1. curriejohn
    Feb 17, 2015
    14
    Hi
    Would some body be able to show me the correct format on how to calculate the Gain for the attached circuit.
    I know Av = Vout/Vin but what is the best way to find out Vout!!!! Hope this makes sense.
    Thank you in advance.
  2. KLillie
    Member
    May 31, 2014
    126
    14
  3. KLillie
    Member
    May 31, 2014
    126
    14
    This looks like homework. If it is, they do have a section for that. If not, I'm thinking you may have to make some assumptions about your circuit.
  4. crutschow
    Mar 14, 2008
    13,518
    3,386
    Do you need the exact gain equation or just an approximation?
  5. WBahn
    Mar 31, 2012
    18,093
    4,918
    MOD NOTE: Moved to Homework Help from General Electronics Chat.
  6. WBahn
    Mar 31, 2012
    18,093
    4,918
    What do you know so far about small-signal analysis of BJT circuits?
  7. curriejohn
    Feb 17, 2015
    14
    Hi Crutschow
    I just need the equation that will give me the Vo of the attached circuit so i can then calculate the Gain Av. Its a part of my home study college work that i am completing to upgrade my qualifications. I come on here to get some professional help from guys like you as studying from home with no tutor is fairly difficult.
  8. mxg2579
    Jun 10, 2015
    15
    7
    Well like WBahn asked, do you know about small-signal analysis of BJT's? You will need to set-up the small signal analysis circuit and from there you will see Vin and Vout, and all you have to do is write some loop-equations, etc. to get Vout in terms of Vin.
    If you look on wikipedia for "Hybrid-Pi model" there is a pretty good illustration of the model and the associated equations. See if that helps
    curriejohn likes this.
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
