bits/pixel
Discussion in 'General Electronics Chat' started by tojeena, Jul 1, 2013.
  1. tojeena
    Thread Starter Active Member
    May 2, 2009
    118
    In one paper i read giving values bits/pixel in the range 0.25-2.?what does it mean?will it affect the psnr?psnr is dependent upon B,dynamic range,does bits/pixel(rate) has any relation with dynamic range also?
  2. donpetru
    Nov 14, 2008
    186
    25
    The number of distinct colors that can be represented by a pixel depends on the number of bits per pixel. A 1 bpp image uses 1-bit for each pixel, so each pixel can be either on or off. Each additional bit doubles the number of colors available, so a 2 bpp image can have 4 colors, and a 3 bpp image can have 8 colors:
    • 1 bpp, 2^1 = 2 colors
    • 2 bpp, 2^2 = 4 colors
    • 3 bpp, 2^3 = 8 colors....
    Peak Signal to Noise Ratio (PSNR) is the ratio between the maximum possible power of a signal and the power of corrupting noise that affects the fidelity of its representation.
    For example,
    PSNR = 10 * log10 (M^2/Ms);
    where: M is the maximum possible pixel value of the image (if you using 8 bits per sample, M is 255); Ms is mean squared error (MSE).
  3. tojeena
    May 2, 2009
    118
    what about the gray scale image ?in the particular paper they have given bpp from 0.5 -2 range? so psnr doesnt depend on bpp?:confused:
  4. donpetru
    Nov 14, 2008
    186
    25
    Look at mathematical formula that defines PSNR. In the mathematical formula there is a term denoted by "M" which, according to its definition, is directly proportional to bpp. So, we can say that: PSNR depend on bpp.
    tojeena likes this.
  5. tojeena
    May 2, 2009
    118
    thank u for the reply.what does it mean to give manually bits/pixel or compression rate from 0.25 to 2
