Biting off more than I can chew?
Discussion in 'The Projects Forum' started by Camwill, Dec 30, 2014.
  1. Camwill
    Dec 30, 2014
    Hello all. I am something of a tinkerer and have many hobbies. I would like to design a piece of hardware to control the microclimate in a small greenhouse. Essentially it would control a series of humidifiers and in the future a heater.
    Now when I say I have no experience in electronics that means I haven't touched a breadboard since middle school in 99... I understand some basic principals but as far as selecting components or designing a schematic? Clueless.
    If anybody has built something like this, or could point me in the right direction I would be very appreciative.
    Happy New Years!
  2. blocco a spirale
    Jun 18, 2008
    1,463
    372
    First off, define the interfaces.
    i.e. how many inputs? what type of inputs are they; analogue/digital? What currents and voltages are involved? How many outputs? etc....
  3. crutschow
    Mar 14, 2008
    13,529
    3,393
    It sounds like you likely would want a computer or microprocessor to control everything.
  4. blocco a spirale
    Jun 18, 2008
    1,463
    372
    I think a small PLC would be most suited to this application.
    Sinus23 and MaxHeadRoom like this.
  5. wayneh
    Sep 9, 2010
    12,406
    3,256
    That's fine, but there are commercial systems for doing this. Doing one yourself will take time and possibly cost more than just buying one. Again, that's fine as long as you're fully aware. Reverse engineering the major functions of the commercial devices may simplify your design.
    If your heater is electrical, as opposed to gas, that will likely be your highest power load to control and you should design with that in mind; size your relays large enough to handle that load.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    I've been controlling the temperature and humidity in whole houses and small factories for 40 years. Buy a thermostat and a humidistat and wire them to your heater and water source.
    Then again, you said you want to design a piece of hardware.
    OK. You can start by designing a thermostat. When you get done with that, work on the humidistat.
  7. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    In the form of a Smart Relay maybe?
    Max.
  8. blocco a spirale
    Jun 18, 2008
    1,463
    372
  9. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    There are quite a few out there, some appear to be just relabeled.
    Omron, Idec, Siemens, Sneider, Some will offer the S/W free, but almost all can be programmed from the front buttons.
    A nice feature is they usually include a 24hr clock.
    Max.
  10. blocco a spirale
    Jun 18, 2008
    1,463
    372
    The Zelio software is free and includes a simulator. It's very easy to use and anyone can start programming with it almost immediately.
  11. CrashBang_Proto
    Dec 31, 2014
    If you're simply looking to solve a problem then some of the items discussed above will help. However it sounds like you want the challenge of building it yourself, rather than simply solving a problem. If that's the case, then you're only taking the first step of a very long journey - and I doubt anyone here will be able to walk you through that.
    Many people start using microcontrollers as they're pretty easy (relatively) to program logic into - take a look at www.arduino.cc and some of their resources. From there... Google is your friend, I'm afraid.
  12. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    One advantage to the Smart Relay is the I/O is already conditioned for P.B. input and relay output.
    The language has a shorter learning curve than Micro's if one has never used a micro before.
    Max.
    CrashBang_Proto likes this.
