Bit Shuffler - use a MUX?
Discussion in 'Homework Help' started by hello86, Mar 4, 2008.
  1. hello86
    Mar 4, 2008
    Hello, I have a homework question that I have no idea where to start with.
    Any advice on how to take apart the question would be useful.
    Here it is:
    A shorthand notion for representing a group of wires is: A[3:0] which basically means its A3 A2 A1 A0, 4 bits.
    Design a circuit that conforms to the following:
    Input: A[3:0] - 4 bit input
    S - 1 bit input
    Output: D[3:0] - 4 bit output
    Operation specifics:
    If (S=1) then D[3:0] = A[3:0] --> D[3] = A[3], D[2] = A[2] etc
    If (S=0) then D[3:0] = A[2:0], 0 --> D[3] = A[2], D[2] = A[1], .. D[0] = 0.
    I mean I thought I could use a multiplexer where S is the select button. So, essentially you select the inputs to be equal to the outputs when the Select value is 1.
    When select is 0, you shift everything?
    Thank you!
  2. Dave
    Retired Moderator
    Nov 17, 2003
    Sounds like you want a PIPO shift register (ref., in your case S would be the mode operation.
    This shift register uses parallel in and out, however you could look at serial input and/or output. The net effect of the shift register is the same, it just in the implementation.
