Bit rate
Discussion in 'Computing and Networks' started by Lightfire, Jan 23, 2012.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Source: Wikipedia
    Please help me.
    What does this mean.
    How to determine/know the number of bits of a certain video??
    Thnx
    zumiao likes this.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    For video, think of the data rate required for a low resolution, say, 800x600 pixels. Each pixel has 3 color values, so you end up with 24 bits per pixel.
    If the display is refreshed 60 times per second, how many bits per second does the video card need to transmit to the display?
    How much more data is needed to be transferred when displaying 1720x1080 at 30 frames per second?
    Calculate that out and you'll see why HDTV can't be effectively broadcast with the old analog standards.
  3. Lightfire
    Oct 5, 2010
    690
    21
    691,200,000 bits per second or 86,400,000 bytes per second?
    So I need at least 86.4 megabytes per second internet connection? I can't afford that. ;)
    Am i right anyway?
    thnx
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    That is why video data is compressed.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Yes, that's why HDTV is 100% incompatible with the older TVs and analog broadcast methods.
    Now the data is converted to digital, where it can be rather highly compressed, with some loss of quality, but sent over a much smaller bandwidth connection, be it radio waves, cable TV, or Internet.
  6. Lightfire
    Oct 5, 2010
    690
    21
    Thnx MrChips and thatoneguy.
    I looked up the details of my recorded video and here what I saw.
    Length: 00:02:43
    Frame width: 640
    Frame height: 480
    Data Rate: 12,544kbps
    Total bit rate: 12,632kbps
    Frame rate:20 frames/second
    What's the difference between the two, data rate and total bit rate. thnx
    anyway, how to know how many frames are there in video? thnx again
    thnx
  7. Markd77
    Sep 7, 2009
    2,803
    594
    Number of frames is about length X frame rate = 163 seconds X 20 = 3260
    Length has probably been rounded to the nearest second so it could be up to 20 frames higher or lower.
  8. Lightfire
    Oct 5, 2010
    690
    21
    Ok,.
    pls help me where i can stream videos online. pls
    thnx
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    www.ustream.com
    That's how a bunch of people in Japan got their video out of the Tsunami and earthquake before services were lost, same goes for the Egypt riots before Egypt killed the Internet routers there.
  10. Lightfire
    Oct 5, 2010
    690
    21
    Thnx thatoneguy.
    I dont know how can i stream a recorded(not live) video.
    Help pls.
    Thnx
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    Sign up for a free account, and they have instructions on how to walk you through it.
    Using something like VLC player will allow you to make a streaming video from a pre-recorded source.
