Bit banding/Software uart RPI2 Model B
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Sep 24, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have model B RPI2. I am already using one uart on it.
    is there any software/bit-banding uart library available ?
    2. On search i found here. but it don't have any example code.
    http://abyz.co.uk/rpi/pigpio/python.html
  2. sirch2
    Jan 21, 2013
    1,008
    351
    Sorry, can't help with your question but I think you mean bit-banGing, as in to bang a drum? This may help you get better results from Google.
  3. BR-549
    Sep 22, 2013
    2,181
    419
    These are two separate things.
    Bit Banging and Bit Banding.
    Bit Banging is using the processor to set logic levels for communication or I/O. i.e....manual I/O.
    Bit Banding is using a whole memory location to represent one bit. When you use that location.....it represents one bit in another register.
    I didn’t explain that too well. You can look both up.
    Sorry, not familiar with your unit or python. The unit site should have links to all the libraries.
  4. nigelwright7557
    May 10, 2008
    488
    71
    A software UART isn't too difficult to write.
    Just send out the bits as zeroes or ones with correct delay between bits.
    Don't forget to add start and stop bits.
    Receive is just the opposite , read in bits with the correct delay between them.
