Birthday date project
Discussion in 'Homework Help' started by saruman42, Dec 7, 2011.
  1. saruman42
    Dec 7, 2011
    Hello all, I am currently working on a project that requires me to build a circuit on multisim and then breadboard the design. I am currently having trouble in the multisim portion of the project. I'm posting all the information regarding what I have below.
    What I'm supposed to do:
    Design a combinational logic circuit and display it results on a seven-segment display
    I have attached a photo of what I have done.
    Birthday Boolean
    (sorry, the truth table gets a bit messed up when I copy it in here)
    A B C Date a b c d e f g
    0 | 0 0 0 0 0 0 0 0 0 0 1
    1 | 0 0 1 1 0 0 1 1 1 1 1
    2 | 0 1 0 - 1 1 1 1 1 1 0
    3 | 0 1 1 2 0 1 0 0 1 0 0
    4 | 1 0 0 1 0 0 1 1 1 1 1
    5 | 1 0 1 - 1 1 1 1 1 1 0
    6 | 1 1 0 9 0 0 0 1 0 0 0
    7 | 1 1 1 4 0 0 1 1 0 1 0
    Equations:
    a = A’BC’ + AB’C
    b = A’BC’ + A’BC + AB’C
    c = A’B’C + A’BC’ + AB’C’ + AB’C + ABC
    d = A’B’C + A’BC’ + AB’C’ + AB’C + ABC’ + ABC
    e = A’B’C + A’BC’ + A’BC + AB’C’ + AB’C
    f = A’B’C + A’BC’ + AB’C’ + AB’C + ABC
    g = A’B’C’ + A’B’C + AB’C’
    All together:
    (A’BC’ + AB’C) + (A’BC’ + A’BC + AB’C) + (A’B’C + A’BC’ + AB’C’ + AB’C + ABC) + (A’B’C + A’BC’ + AB’C’ + AB’C + ABC’ + ABC) + (A’B’C + A’BC’ + A’BC + AB’C’ + AB’C) + (A’B’C + A’BC’ + AB’C’ + AB’C + ABC) + (A’B’C’ + A’B’C + AB’C’)
    Simplified:
    a = AB’C + A’BC’
    b = A’B + AB’C
    c = AC + B'C + AB' + A'BC'
    d = A + B'C + BC'
    e = B'C + A’B + AB'
    f = AC + B'C + AB' + A'BC'
    g = A'B' + B'C'
    (AB’C + A’BC’) + (A’B + AB’C) + (AC + B’C + AB’ + A’BC’) + (A + B’C + BC’) + (B'C + A’B + AB') + (AC + B'C + AB' + A'BC') + (A'B' + B'C')
    NOTE: U7 AND is currently unattached.
    Thanks in advance for any help.
    [​IMG][​IMG]
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    The images don't show as they are links to your local computer.
    You can upload the images to our server:
    Bertus
    saruman42 likes this.
  3. saruman42
    Dec 7, 2011
    Thanks for the advice, I attached the photo.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    From what I understand, you want to display the rolling message "01-21-94". Check for a bit this link (http://en.wikipedia.org/wiki/7_segment), and see which segment (a,b,c...) is which. Are you sure you have your outputs correctly? Because, for instance, {abcdefg}={000001} isn't the code for 0.
