Hi - just joined, first post.
Taking my first steps in electronics, I've found several points I'm really puzzled about. Maybe you can help?
First One:
The bird sitting on the electric power line scenario - there's zero voltage differential between its feet, so it doesn't get electrocuted.
But if you put one probe of a voltmeter on the power line, and stuck the other probe up the bird's butt, would it not show a voltage differential between the power line and the internal environment of the bird?
If NOT - wouldn't that imply that the bird's body (which is presumably not electrically charged) and the power line (full of amps and amps of current being pushed around by high voltage) somehow by amazing coincidence just happen to each possess an electric field with exactly the same potential energy per unit charge (since that is what voltage is defined as)? How and why would that be the case?
And if the voltmeter would show a voltage differential, why does an electric current not flow into the bird? Wouldn't Ohm's law mean that a current, at least momentarily (until an equilibrium is reached and there is no longer any voltage differential), would flow into the bird and that current would initially be equal to the initial voltage differential between the power line and the bird, divided by the resistance of the bird?
So can anybody explain how these birds are getting away with it!?!?
Clearly they know something that I don't.
Thanks.
First One:
Thanks.
