Bipolar vs. cmos
Discussion in 'General Electronics Chat' started by new2circuits, May 5, 2009.
  1. new2circuits
    Apr 22, 2009
    21
    HI:
    I'm trying to understand the difference between bipolar and cmos signals and why one would be chosen over the other in certain applications.
    Also, do bipolar input signals always requirea dual supply ?
    And if so, why?
    Any reference material is welcome.
    Thanks in advance.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Both refer to transistors, or logic. Dual power supply is a non-sequitur, since both also use single power supplies.
  4. mik3
    Feb 4, 2008
    4,846
    63
    The chose depends upon the application. In switch mode power supplies they usually use MOS because you can control large amount of current by applying only voltage to the MOS gate.
    BJT's require a significant base current to switch high currents but they switch faster than MOS due to their higher transconductance.
    Also, MOS have a positive temperature coefficient whereas BJTs negative. This prevent thermal runaway of which BJTs suffer. This allows MOS to be paralleled too.
    Search google and you will learn more.
  5. new2circuits
    Apr 22, 2009
    21
    Thanks for your inputs. Much appreciated.
