bipolar transistor inverted output
Discussion in 'Homework Help' started by smarch, Mar 25, 2010.
  1. smarch
    Thread Starter Active Member
    Mar 14, 2009
    52
    Just one quick simple question, with a self-biasing transistor circuit, why when putting in a square wave input would you get an inverted output response?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. smarch
    Mar 14, 2009
    52
    so what's the answer, i can't see anything in that link that explains to me why.
    thanks
  4. Bychon
    Member
    Mar 12, 2010
    469
    41
    When the base goes positive, the transistor turns on. That means currrent flows to ground and the collector has minimum voltage on it. When the base is grounded, the transistor is "off" and the voltage at the collector can't get through the transistor. Therefore, the voltage at the collector is "high"...whatever the supply voltage is.
