Bipolar supply +/- help (Single transformer)
Discussion in 'General Electronics Chat' started by oidium45, May 25, 2010.
  1. oidium45
    Thread Starter Active Member
    Apr 24, 2010
    130
    8
    I am trying to get both a positive and negative supply from one transformer. The bigest problem that I am having is that the positive needs to be +24-48v and the negative needs to be -10v. Will the below drawing work (raw power supply for regulators)? If not can someone please recommend an alternative?
    I have included the basic circuit that I am trying to build as well.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I would take a separate small transformer for the - 10 Volts and a large transformer for the power section.
    The standard LM317 can only handle upto 40 Volts at its input.
    There is also a high voltage type of the LM317, the LM317AHV.
    That one can handle upto 60 Volts.
    (see datasheet for more info).
    Bertus
    oidium45 likes this.
  3. oidium45
    Apr 24, 2010
    130
    8
    Thank you Bertus! I meant 32-40v input. My mistake... Actually I will probably be using a maximum of 36v for the input. I am still having difficulty figuring out how to get the negative supply voltage, but a small transformer is definately something that I do not mind adding to the circuit.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The "help" transformer for the - 10 Volts can be really small.
    A transformer that handles 100 mA would probably be enough.
    Something in the range from 7 to 9 Volts will do.
    The Fets act as current sources, the voltage is not that critical.
    Bertus
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ask yourself - what circuit might you want to power from less than 1.25 Volts?
    You really don't want that large of a voltage differential across an LM317 anyway (I'm speaking of 36v in, and a lot less out) because for a given current, power dissipation in the LM317 will get much higher as it's output voltage goes lower.
    For a 36v input, tell me what the power dissipation in the load and the LM317 will be, when the load requires 1 Ampere of current; first at 33V (output of the LM317, input to the load), second at 18v, and thirdly at 3V.
  6. oidium45
    Apr 24, 2010
    130
    8
    Bertus, I thought about using a smaller transformer for the negative but I still run into the problem of not knowing how to connect it into the circuit. Let me explain a bit better.
    1) Could I power the second transformer off of a winding from the main transformer? Or do I need to use a 120-10v transformer?
    All information that I have found suggests that if I use a single transformer with two bridge rectifiers they will short each other out. But I have found no information about using one of the windings for a second transformer instead.
    2) How would I connect the second transformer output into the circuit? Would I connect the negative to the transistor, ground to the main ground of the circuit, and leave the positive "hanging"?
    3) Can I create a 36v power supply from one winding on the transformer, and use a seperate center tapped winding on the same transformer to generate the -10v?
    Sgt Wookie,
    I understand the issue with heat dissipation. I believe I have that problem solved for now. "hopefully"... I am planning to try using a variable input adjustable through a rotary selector switch. This will allow me to adjust the input voltage to the LM317 to more closely resemble the output voltage requirement.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
