Bipolar stepper motor 2-wire vs 4-wire control with H-Bridge? Arduino UNO R3
Discussion in 'The Projects Forum' started by geratheg, Apr 21, 2015.
  1. geratheg
    Jul 11, 2014
    107
    I want to control a Bi-Polar stepper motor using an H-Bridge and an Arduino UNO Rev3 as the controller. I have two questions:
    1. I would like to know if there is any advantage to using 4-wire control over 2-wire control with the Arduino Uno Rev3?
    Here is the tutorial I'm following:
    https://itp.nyu.edu/physcomp/lessons/dc-motors/stepper-motors/
    They mention using an L293D H-Bridge, but I will be using an SN754410 H-Bridge since I read that it is a pin-to-pin replacement for the L293D and I need to drive about 700mA of current.
    I'm assuming it will work as a pin-to-pin replacement with the 4-wire control setup.
    2. Is the SN754410 also a pin-to-pin replacement with the 2-wire control setup?
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    Pro = less wires/pins used..
    Con = more components to fail..
  3. geratheg
    Jul 11, 2014
    107
    Thanks for responding. Are there any performance differences?
