Here's another ?? How can you have a power rail that is -12v (any number would work here)? I always assumed that when you got to zero volts you found ground. Then i started to study amplifier schemos and low and behold, there are two power rails, one +, and one -. Obviously this left me unsettled. How do you go past ground? Most people, me thinks, see this the same way. + or -, positive or negative, full or empty. So, in my mind, what is - voltage. A voltage vacuum of course! Like a black hole, capable of sucking stray voltages into oblivion. Of course not. I started thinking, maybe it's like biasing a bjt to amp a/c on a single rail. My understanding is to do this you let the base of the bjt think that the midpoint in your PS, say a 9v battery is ground. (or circuit common) Thereby allowing for a swing +4.5v and -4.5v. Of course, as with anything else, I have only you folks to tell me if my assuption is correct. So, i found a power transformer the other day, it was rated 25v. There was no "pin out" diagram on it but on the side of the case it said 12.5v-0v-12.5v. AHA, this is it. The explanation i've been waiting for.... this must mean that your positive rail it actually 25v-12.6v, then circuit common, then your nagative rail is 12.5v-0v. Yes, that must be it. I thought on that for a few minutes and it dawned on me how absolutely absurd that idea was. Apparently, I've discovered a way to learn in reverse. Instead of learning new things when I study, I forget other things I thought I knew. Just to check, 1Ω represents less resistance than 1MΩ. Surely, i'm losing braincells. So, then the other day i'm changing the batteries in a semi at work (im a diesel mechanic) I start thinking, if you put the test lead of a multi meter on the POS terminal of a battery and the common lead on the NEG you will get +12v or thereabouts. (on a good batt of course) Conversely, if you switch them round you see -12v. This could be useful. So thats a matter of what the meter see's as ground? Like those old mostly European cars that had the POS terminal of the battery cabled to the frame instead of the NEG. So, in this case, have I been going about this all wrong? Perhaps I should view the + and - more as phase, or polarity that as absolute positive and negative? That make a whole lot more sense to me. But is that correct? Could I also take that to mean that the ever mystifying current may in fact be moving on opposite directions on the rails? Help....help....help??? Bueller...............Bueller.............Bueller.........
