bipolar junction transistors
Discussion in 'Homework Help' started by 87shovelhead, Nov 3, 2007.
  1. 87shovelhead
    Nov 3, 2007
    1- How many regions of operation does a bipolar junction transistor have and which region has to dissipate the most heat
    2- In a biopolar junction transistor, collector current is controlled by what? a-collector voltage b-base current c-collector resistance or all of the above
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    These sound like homework questions.
    All of these answers can be obtained using google.
    hgmjr
  3. Management
    Sep 18, 2007
    306
    Do you have a textbook?
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  5. extremeads1
    Feb 10, 2007
    64
    3 regions of operation : 1) Saturation 2) Cut-off 3) Active
    It basically acts as a switch in first 2 regions of operation and an Amplifying action takes place in the third region.It is a current controlled device as a base current (Ib)controls the collector current(Ic) in case of CE (Common Emitter )configuration. search wikipedia http://en.wikipedia.org/wiki/Transistors for general information.
