Bipolar junction transistor analysis at emitter.
Discussion in 'Homework Help' started by lam58, Jan 12, 2014.
  1. lam58
    Jan 3, 2014
    69
    Hi for the question in the attached image below, would
    Ve/Vs = [hfe*Re]/[Rb + hie + (hf'e*Re)], with hf'e being the value I found for Vc/Vs?
      File size:
      72.2 KB
      41
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I would rather have:
    \text{\frac{V_e}{V_s}=\frac{R_E(1+h_{fe})}{R_B + h_{ie} + R_E(1+h_{fe})}}
    where hfe is the value per the original problem statement.
  3. The Electrician
    Oct 9, 2007
    2,301
    339
    What's the difference between hfe and hf'e? I never did see an explanation for that in the other thread.
  4. Efron
    Member
    Oct 10, 2010
    81
    15
    t_n_k is right.
  5. lam58
    Jan 3, 2014
    69
    Ok but would Vc/Vb stay as (-hfe*Rc)/{Rb+hie + (Re*hfe)} or would this also be Re*(hfe + 1)?
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    Do you know why we use (hfe+1) ??
  7. lam58
    Jan 3, 2014
    69
    Not entirely, I think it's because it's the resistance Re + the resistance of the emitter Re affected by the hfe of the junction?
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    We use hfe+1 because the emitter current is equal to
    Ie = Ib + Ic = Ib + Ib*hfe = (hfe + 1)*Ib
    And this is why Re resistor is seen at the base as (Hfe +1)*Re
    lam58 likes this.
  9. lam58
    Jan 3, 2014
    69
    So to clarify my initial question is yes it would be (Re*hfe+1)/{Rb+hie+(Re*hfe+1)}? :)
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Check your parentheses
  11. lam58
    Jan 3, 2014
    69
    Sorry just spotted it (Rc*hfe)
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    But you in post 9 show equation for the voltage gain
    The correct one is Ve/Vb = (Re*(hfe+1))/{Rb+hie+(Re*(hfe+1))
    But now Vc/Vb = ?
  13. The Electrician
    Oct 9, 2007
    2,301
    339
    Sometimes you are asking about Ve/Vs and Vc/Vs, but other times it seems to morph into Ve/Vb and Vc/Vb.
    What do you understand to be meant by Ve/Vb as opposed to Ve/Vs? Wouldn't Vb mean the signal voltage at the base directly, whereas Vs is the signal at the left end of Rb? So, Ve/Vb is a different gain ratio than Ve/Vs?
    Please be absolutely clear which you are asking about.
  14. lam58
    Jan 3, 2014
    69
    It's supposed to be Vc/Vs, it's just a typo.
    Vc/Vs= (hfe*Rc)/{Rb + hie +(Re*1+hfe)}
    Although technically wouldn't Vc/Vs = Vc/Vb since R1, and R2 are ignored?
  15. lam58
    Jan 3, 2014
    69
    If there were a capacitor across Re that grounded/shorted Re, would Ve/Vs still = \text{\frac{V_e}{V_s}=\frac{R_E(1+h_{fe})}{R_B + h_{ie} + R_E(1+h_{fe})}} ?
  16. Jony130
    Feb 17, 2009
    3,993
    1,116
    OK, now every thinks looks good except one small detail.
    The voltage gain Vc/Vs is negative because transistor in common emitter configuration have 180 degree phase shift.
    When the base current increases the collector current also increases.
    As you can see when input voltage is increasing ( base current also) the Vce voltage decrease. So we have 180 degrees out of phase (negative gain).
    lam58 likes this.
  17. lam58
    Jan 3, 2014
    69
    Ahh ok, I see. Thanks:)
  18. Jony130
    Feb 17, 2009
    3,993
    1,116
    No ,try to use small signal analysis and you will know.
  19. lam58
    Jan 3, 2014
    69
    Would there be no gain since Re is grounded meaning Ve/Vs would = Vs?
  20. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, how can we talk about the voltage gain in circuit in which we short our output terminal to ground.
