I need to generate an analog signal ranging between -10V and 10V using a 3V MCU. I'm wondering what the best approach is going to be. My plan is to implement the DAC using pwm and a lowpass filter.
Does it make more sense to use an h bridge to pwm the +-10V rail directly, or generate a 0-3V analog signal and use opamps to shift/scale the output voltage?
