Bipolar common emitter voltage
ham3388
Joined Jul 3, 2012
97
Hi again dear friends. , hope all are doing well.
Please could some one evaluate my work and advise me in case any correction isrequired.
Have a good dayScreenshot_2016-10-15-11-54-09.jpg 20161015_113525.jpg 20161015_113535.jpg 20161015_113642.jpg
WBahn
Joined Mar 31, 2012
30,045
What steps have you taken to check your results?
Which do you expect to have the higher Vbe, the answer to (i) or the answer to (ii)?
ham3388
Joined Jul 3, 2012
97
Thanks Bordodynov...
The Vbe voltage is not matching with the values that obtained by me...
So what has gone wrong, I'm wondering.
Can you suggest where is my mistake?
Bordodynov
Joined May 20, 2015
3,179
i. 25e-3*ln((5e-3/0,98e-13)+1) = 0,6163872887428
exp(Vbe/25mV)-1=5e-3/0,98e-13
exp(Vbe/25mV)=5e-3/0,98e-13+1
Vbe/25mV=ln((5e-3/0,98e-13)+1)= 24,65549154971
24,65549154971*25e-3 = 0,6163872887428
I shall understand with program LTspice, why program gave the value-added result.
ii. if Vce=const=5V ==>
Vbe(9.95mA)=25e-3*ln((9,95e-3/0,98e-13)+1) =0,633590654711
but Vce != 5V Vce=(10V-1000*9.95)=50mV Vbe-Vbc=50mV !
That must be taken into account for the calculation of both terms of the equation
Make the equation. Unfortunately for accurate calculation of the gain "ar" needed.
ham3388
Joined Jul 3, 2012
97
Thank pal for your time
I appreciate you
Please see below
I don't understand the hi lighted once.
Which formula you have used.
Can you explain this for me because I'm confused little bit since they are not according to my formula
Bordodynov
Joined May 20, 2015
3,179
I figured out with LTspice.
With regard to my calculations. In the beginning I wrote the final result, and then brought the detailed steps.
Do not pay attention to the second calculation result.
In the case of 9.95 mA compose equation Ebers-Mole. Take as I ar = 0.5 (af = 0.98). Drop unit in parentheses (because of their smallness in comparison with the exhibitors). Add the equation Vbe-Vbc = 50mV. Use the properties of the exponential exp (A-B) = exp (a) * exp (-b)
ham3388
Joined Jul 3, 2012
97
Thanks very much Bordodynov
You are great
Finally I got the correct values
Again I say thank you very much since you paid attention to my thread.
Godby for timbieng.
