Biomedical Engineering - Amplifier
Discussion in 'Homework Help' started by Paradoxs, Dec 28, 2014.
  1. Paradoxs
    Dec 28, 2014
    Hello
    1- What is application of this circuit? What does it do?
    2- Simulate this circuit in a simulator software and by determine correct values for resistors, show heat losses (H) is nearly constant.
    3- Calculate H analytically (manually) (voltage division) and compare with part 2 in a software.
    Hint: [​IMG] (Comparator)
    4- By proper ratio selection for resistors, show sensitivity of heat losses (H) with respect to thermal resistance (Rt) is almost zero.
  2. blocco a spirale
    Jun 18, 2008
    1,457
    369
    That's an interesting set of questions. Thanks for sharing.
    I assume that since you have posted this under Projects that this is something you're building?
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Good point. Might take a pair of PhD's to work on them. ;)
    Paradoxs likes this.
  4. Paradoxs
    Dec 28, 2014
    Sorry, I should've posted this under Homework but this is like a project!
