Binding Post and Plugs
Discussion in 'General Electronics Chat' started by R!f@@, Mar 2, 2014.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    Binding Post
    Banana Plugs
    For all I know, the above can handle around 10 Amps.
    Or am I wrong ?
    Can any one confirm this for me. :)
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    I've seen banana plugs rated up to 15A..
  3. PackratKing
    Jul 13, 2008
    850
    216
    There are *bananas* that are simply folded-over sheet,[ cheep ] and then there are those that are either Bi, or Quad-furcated rod stock...
    I believe the latter to be good for at least 15 amps, if both pin and socket are good and clean...and a decently tight fit.
  4. ErnieM
    Apr 24, 2011
    7,434
    1,624
    Plugs I see thru US distribution are rated 15A.
    However I see no ratings on these knock offs.
    Let me know how they work in case I am temped to get some.
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    It will take some time . :D
    I checked ebay and they are cheaper.:eek:
    What do you think of these knockoffs
    I asked the seller about the current capacity.
  6. MrChips
    Oct 2, 2009
    12,622
    3,451
    Banana plugs and jacks are rated at 15A. I would prefer to use spade connectors instead of plugs for a more secure connection.
    R!f@@ likes this.
  7. R!f@@
    Apr 2, 2009
    8,785
    771
    ThnX chips.
    The ebay listing seller is in Aliexpress too :eek:
    Ali listing is more expensive and out of stock.
