binary weighted DAC help plzz
Discussion in 'Homework Help' started by koneur, Jan 14, 2010.
  1. koneur
    May 21, 2009
    8
    how can i derive output voltage for a 8 bit binary weighted DAC?????
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. koneur
    May 21, 2009
    8
    there no output voltage derivation :(( where can i find formulas..maybe solved problems for DAC or ADC i have a final exam tomorrow really stucked on it :(:(:( but i am sure its very very simple to calculate ADC and DAC output voltages
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Every ADC and DAC do have a voltage range. As an example let us say an ADC have a input range equal min -5 volt and max +5 Then the total range is +5 volt-(-5 volt)=10 volt. If this ADC have 10 bit each bit will have bit weight equal to range/(2^10)=0.009765625 volt
    If we have an ideal ADC with the latter specifications and apply 2.5 volt the ADC will output the number 256. Also remember an ADC output is based on integer values
  6. koneur
    May 21, 2009
    8
    that the questions will be not detailed..it will be very very basic DAC (mostly) and ADC calculations just simply..for instance it'll given Vr , Rf , and R..also R varying as LSB or MSB for all these conditions they may ask me to find output voltage (for DAC)
  7. StayatHomeElectronics
    Sep 25, 2008
    864
    40
  8. koneur
    May 21, 2009
    8
  9. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    You can easily use superposition to solve the problem.
    Calculate the Vout with respect to V1 by setting V2=0 and V3=0. Repeat for V2, setting V1=0 and V3=0, and V3, setting V1=0 and V2=0. Add the Vout's together.
    The process is the same for a larger number of bits...
  10. koneur
    May 21, 2009
    8
    thanks much
