Sorry forgot to say that this is programming in C.
Hi, I'm doing some programming practice for fun and decided to write a simple program that converts binary to decimal based on the well known algorithm. For those who don't know for some reason, the algorithm is as follows:
Say you want to convert 1101 to decimal.
You do: 1*2^0 + 1*2^2 + 1*2^3 = 13
Below is my code. The program runs but gives wrong answers. I don't understand why. I checked that the array contains the binary bits that the user enters. Then I use each element of the array as the bit location LSB to MSB, and loop through them to get the sum.
Rich (BB code):
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
int main()
int a[32],n,i,j,m;
int sum =0;
double g = 2;
printf("Enter the number of bits in your binary number\n");
scanf("%d",&n);
printf("Enter the binary number with a space after every bit\n");
for (i=0;i< n;i++);
scanf("%d",&a); // get binary number from user and enter it into array a
for (j=0; j<n;j++);
if (a[j] == 1); // test if the bit is a 1, if so do 2^ bit index
m = pow(g, j);
sum = sum + m; // add all the 2^ bit indices for the bits that are 1 to get the decimal number
printf("Your binary number in base 10 is %d\n", sum );
