binary subtraction arithmetic!
Discussion in 'Embedded Systems and Microcontrollers' started by Eric007, Apr 14, 2012.
  1. Eric007
    Thread Starter Senior Member
    Aug 5, 2011
    1,054
    33
    Hello!
    Can someone show me how to do this little calculation? I'm a bit confused!
    00000 - 10011 = ?
    00000 - 00010 = ?
    00000 - 00011 = ?
    Please show me how you do the borrowing and all that!
    Thanks in advance!
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    Computers do not do subtraction.
    The simplest solution is to form the 2's complement and add.
  3. Eric007
    Aug 5, 2011
    1,054
    33
    There must be a good reason why i'm asking this question...
    Actually i'm multiplying signed number using 'Booth's Algorithm'
    But yeah your " 2's complement and add" method works.
    In fact, you perform a 2's complement only on the 'signed' number then you add.
    --» 00000 - 00010 = 11110
    --» 00000 - 00011 = 11101
    --» 00000 - 10011 = 01101
    Thanks MrChips!
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Try a goolge search on binary arithmetic
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Eric007 likes this.
  6. Eric007
    Aug 5, 2011
    1,054
    33
    I did but the examples on google are too TRIVIAL and obvious but anyways I figured out how it works.
    Thanks!
  7. MrChips
    Oct 2, 2009
    12,648
    3,458
    Now, see if you can alter the thread title and icon to indicate that you're done with this thread.
  8. chrisw1990
    Oct 22, 2011
    543
    41
    see this thread
  9. Eric007
    Aug 5, 2011
    1,054
    33
    Is it ok now or you want me to add [SOLVED] ??
  10. MrChips
    Oct 2, 2009
    12,648
    3,458
    We have to get the mods to allow the op to change the thread title, not the post title.
  11. chrisw1990
    Oct 22, 2011
    543
    41
    yeh but itll do for now?
