Binary Multiplication
Discussion in 'Homework Help' started by Pedro, May 19, 2008.
  1. Pedro
    May 19, 2008
    First post :) be gentle!
    Doing some revision for my Digital Electronics class which is based loosely around Floyd's Digital Fundamentals textbook. This is the question I need help with;
    a) Discuss the importance of the implementation of multiplications using digital circuitry in an application of of your choice. (5%)
    b) Show the simple process of long multiplication... (10%)
    c) Hence or otherwise, derive a circuit that will implement a 4 bit by 4 bit binary multiplications, making clear the components of your design. (45%)
    d) Design some additional circuitry that will work with the sign bits of the operands and allow the above 4 bit multiplier to be used as part of a 5 bit multiplier that operates on 5 bit, 2's complement numbers. (40%)
    Bold are the ones I need help with. :D I think part A will just be a couple of sentences.
    As for part D I just don't know where to go with my design from part C. Which looks exactly like this;
    http://www.eee.strath.ac.uk/r.w.stewart/digital/multiplier_4bit.pdf
    Cheers,
    Peter
