binary division
Discussion in 'Math' started by manikanta.mashetti, Jan 21, 2014.
  1. manikanta.mashetti
    Jan 13, 2014
    how to divide two binary numbers .if numerator is less than the denominator.
    eg: 6/9 =0110/1001 .
    how to do for the above eg.Is there any algorithms for this ..
    thanks in advance
  2. atferrari
    Jan 6, 2004
    2,674
    785
    Multiplying first, 6 times 10 and then dividing the result of your division by 10?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Same way we do it in decimal. Multiply the number 0110 with a straightforward count until it exceeds 1001, then take the number under that. You subtract (just like the decimal logarithm) the rest is the remainder.
    Binary
    .....___1r11
    0110/1001
    .....0110
    ..... 011
    Decimal
    ..1r3
    6/9
    ..6
    ..3
  4. ErnieM
    Apr 24, 2011
    7,447
    1,628
    The only good thing about binary division is you don't have to guess at the number to multiply the divisor by: it's either larger then the remaining dividend or not, that's one or zero.
    Code ( (Unknown Language)):
    1.         0.10101
    2.      ------
    3. 1001/0110.0
    4.       100 1
    5.       -----
    6.         1 10
    7.      -     0
    8.         ----
    9.         1 100
    10.       - 1 001
    11.         -----
    12.            110
    13.        -     0
    14.           ----
    15.            1100
    16.          - 1001
    17.            ----
    18.              11   and so on...
    (Psst... Bill... you inverted the numbers.)
  5. MrChips
    Oct 2, 2009
    12,657
    3,461
    Shift the dividend one bit to the left into a 4-bit register.
    Subtract the divisor as needed,
    0000 <- 0110
    0000 <- 1100 Q = 0
    0001 <- 1000 Q = 0
    0011 <- 0000 Q = 0
    0110 <- 0000 Q = 0
    fractional part follows:
    1100 <- 0000 Q = 1, R = (1100 - 1001) = 0011
    0110 <- 0000 Q = 0
    1100 <- 0000 Q = 1, etc
    Result is 0000.101010
  6. WBahn
    Mar 31, 2012
    18,096
    4,920
    The first thing you need to do is decide what representation you are going to use for your result? quotient/remainder? Fixed point? Four bits? Eight bits? Where will the radix be? All of these affect the algorithm in ways small and great.
