Binary Divider
Discussion in 'The Projects Forum' started by xhadow, Nov 18, 2010.
  1. xhadow
    Nov 18, 2010
    I'm working on a project for one of my classes that requires to build a Binary Divider. I've chosen to do the method of Non-Restoring Division; essentially instead of using a subtractor and a comparator, I'd just use a shifter and an adder to simplify the circuitry.
    On paper, I know how to do the arithmetic using the shift and add methodologies in accordance to the previous result. What I'm having trouble with is coming up with a logical design.
    I've attached a very very loose idea of what I'm trying to do. I just need to get the component design down, then from there I'll be able to further break it down (for my class, I need to build everything from the transistor level).
    Suggestions? Please look over my thinking and correct any mistakes you see; thank you ^_^
