Binary Counter using relays
Discussion in 'The Projects Forum' started by basicstamp2, Oct 2, 2008.
  1. basicstamp2
    Aug 30, 2008
    6
    I want to build a binary counter that uses relays but I can't find a schematic does anybody have one?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You can't find a schematic because they stopped doing such things around 1930. The schematics fortunately crumbled to dust before anyone could scan them.
    Why on earth would you want to do such a thing anyway? Electric bill too low?
  3. scubasteve_911
    Dec 27, 2007
    1,202
    audio fanatics sometimes build fancy potentiometers out of a bunch of relays that are switched in binary.. I built one for my friend, but it was all done on a microcontroller.
    Steve
  4. basicstamp2
    Aug 30, 2008
    6
    I want to build a really big and noisy binary clock.
  5. FunkiiMunkii
    Member
    Sep 16, 2008
    12
    Are you making the clock out of 100% relays? Is using digital logic to control the relays out of the question?
  6. basicstamp2
    Aug 30, 2008
    6
    The clock can be made out of anything. I want to use the relays instead of a binary counter IC. I just want to show how comupters worked 70 years ago.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
  8. Bernard
    Aug 7, 2008
    4,248
    424
    Are transistor drivers allowed or we stuck with 12SN7's ?
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not at all - I have a load of 717A's if you want to get the frequentlys up.
  10. neon9
    Member
    Oct 8, 2008
    15
    audio fanatics got to go to MAXIM 2mm digital audio controller.
  11. neon9
    Member
    Oct 8, 2008
    15
    Moderator deleted commentary on project
