binary-ASCII- hex converter digital system
Discussion in 'Homework Help' started by andy24691, May 8, 2011.
  1. andy24691
    Nov 25, 2010
    42
    I have to design and build a system capable of the following;
    1) A 4-bit number is to be obtained from a 4-bit dil switch and on the press of another switch the 7-bit ASCII equivalent is to be transmitted via a simple synchronous serial comm link.
    2) The comm link is to operate on ttl levels and comprises three wires: data, ground and clock.
    3) A receiever is to detect when a transmission has ocured and display the hexidecimal equivalent on two 7-seg displays.
    I am not totally certain of what I am being asked to do my interpretation is you enter a 4 bit binary number i.e. 0-15 in decimal, the ASCII equivalent of the number 0-15 is sent across, though any number greater then nine would be more then 7 bits. Then at the reciever end this is converted to the hex equivalent of the decimal number between 0 and 15. Could you tell me if you agree that this is what I need to do.
    cheers
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Out of curiosity, do you know the ASCII codes for numerals? Is there a code for 15?
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Your reasoning looks ok, but it will be a pain to transmit the data serially and store it for display. I guess, however, that the receiver and the transmitter circuits will be dual to each other.
