binary addition using c++
Discussion in 'Homework Help' started by Gizew, Nov 4, 2008.
  1. Gizew
    Nov 29, 2007
    17
    hey everybody!
    i wnat to write a c++ code that manipulates a binary addition.
    here is what i made:
    for(i=1;i<=n;i++)
    d=(a+[bi])/2;
    if(a==1)
    c=0;
    else
    c=1;
    // a and b are arrays of size n and c is the sum in binary form.
    but the problem arises how to transfer the carry to the next.
    i have tried some what like this:
    if(a==1&&b==1)
    c[i+1]=c[i+1]+1;
    i am not that much sure whether it is correct or not.
    but even in this there is a problem of how to call back the above code.
    (i am not saying that a problem of calling a function).
    can u help u friends?:confused:
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. Mark44
    Nov 26, 2007
    626
    Inside your loop, at each step you need to keep track of whether a carry occurs. If it does, you'll need to do the addition in the next loop iteration. So each loop iteration you'll need to add a + b + carry. The first iteration of your loop, carry will necessarily be 0.
    Having said that, it's not clear to me what kinds of values are in your a and b arrays. Are the elements 1s and 0s?
    What's the purpose of the d array? And why do you put (a + b)/2 into d?
    BTW, your loop is running from i = 1 to i = n. This means that you aren't looking at the 0-th element of any of your arrays. The common practice is to have loops like so: for(i = 0; i < n i++)
