Big donut washer things for system board?
Discussion in 'Computing and Networks' started by spinnaker, Apr 11, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,103
    1,190
    Just got in a new tower case and system board. The case came with these big soft washers.
    I don't remember ever getting these things. Where do they go? Under or on top of the system board? Or somewhere else?
    Case instructions don't list them at all.
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Maybe they hold the case up off of the desk? Just a guess...
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    There are only two places where a shock isolator would make sense: to mount a hard drive and to mount a fan.
  4. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Can you post a photo?
  5. spinnaker
    Oct 29, 2009
    5,103
    1,190
    I think they are probably shock mounts like KJ mentioned.
    But I got the system built and it does not work at all. I am going to test the PSU and post a new thread if PSU tests OK.
  6. spinnaker
    Oct 29, 2009
    5,103
    1,190
    Hey got it up and running. :)
    Not sure what the issue was, maybe a loose connector.
  7. electronis whiz
    Jul 29, 2010
    519
    27
    i have seen these not very often generaly there used between the motherboard back and the case on some systems. i beleve has to do with preventing the bord from shorting out.
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    I believe it goes between ur bum and the chair.
