Bidirectional current sense IC
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Jun 29, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I need to select bidrectional current sense to be used as ammeter.
    2. Going through some of voltage output IC , to be operated at 3.3V.
    3. Since it is ammeter it can high side or low sense or between two loads.
    4. Only problem I have found that IC have miminum CMR, e.g 4V. So I need to have minimum voltage of source to measure current. E.g if I have 1V source & load is 100ohm, I won't be able to measure current through it.
    5. Best I can found is LMP8601 from TI.
    6. Any suggestions on that.
  2. NorthGuy
    Jun 28, 2014
    611
    121
    ina282 and family.
  3. DickCappels
    Aug 21, 2008
    2,779
    674
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    ZXCT1009 (unidirectional) and its bidirectional bretheren at Diodes, Inc
