bidirectional blocking MOSFET
Discussion in 'General Electronics Chat' started by bug13, Mar 16, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    Is there a MOSFET that can block an bidirectional current flowing when it's off? If not, what other choice do I have? I don't want to use a diode in series if possible.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    As a single package? Sounds like you are looking for a TRIAC or SSR?
  3. bug13
    Feb 13, 2012
    1,213
    38
    Not necessary in a single package, can be a combination of a few components, I just want to minimize the voltage drop/losses at low current.
    Triac and SSR might be a bit to slow, I am looking for 200KHz switching frequency.
    edit:
    My tutor told me that I can get an Enhancement MOSFET without a body diode, but isn't the the diode part of the MOSFET internal construction??
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    How's the V,I of your circuit?
    And how's the V cross on mosfet and I flow into mosfet?
    What you need is MOSFET,FET,JFET,or FET in cmos?
  5. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I've always wanted to try two MOSFETs in series to control an AC signal:
    bug13 likes this.
  6. crutschow
    Mar 14, 2008
    13,481
    3,368
    You can also connect two MOSFETs of the same polarity in series back-to-back with their sources connected together, putting their body diodes back-to-back. This blocks current in both directions when the MOSFETs are off but FETs will conduct in either direction when ON (source and drain are interchangeable).
    bug13 likes this.
  7. bug13
    Feb 13, 2012
    1,213
    38
    The Imax = 5A, Vmax=30V, what do you mean by MOSFET,FET,JFET,or FET in cmos?
  8. bug13
    Feb 13, 2012
    1,213
    38
    That looks interesting, is there special requirements to drive this, in term of switching loss? Do these configuration have a technical name for me to do some googling??
  9. ScottWang
    Aug 23, 2012
    4,925
    777
    Different purpose and current using different parts.
    I saw many people that they want to find a diodeless mosfet as you, but it seems only JFET has the character, and I checked the current of JFETs but their current is small for you.
    Someone said that you can using IGBT, but the IGBT is too expensive.
    There is a theory but I haven't try it yet, that is reversing DS, if you want to used it in AC signal, maybe you need more MOSFETs.
    You can see the internal structure of CD4066 or 74HC4066, it's a small current logic and ac switch.
    CD4066 datasheet.
  10. bug13
    Feb 13, 2012
    1,213
    38
    Can you show me a circuit please? thanks
  11. Jony130
    Feb 17, 2009
    3,990
    1,115
  12. crutschow
    Mar 14, 2008
    13,481
    3,368
    Below is the simulation of a bidirectional switch using two back-to-back P-MOSFETs. Looking at the current through V3 [I(V3)] you can see that it blocks in both directions when their gate-source voltage is 0V (Vg at 10V) and conducts in both directions when their gate-source voltage is -10V (Vg at 0V).
    You can also use two N-MOSFETS back-to-back but the voltages would all be inverted. The operating criteria is that the switch is OFF when the gate-source voltages are at zero (or less) and the switch is ON when the gate-source voltage is at or above the full turn-on gate source voltage (typically 10V for standard MOSFETS and 5V for logic-level MOSFETS). Of course the proper gate-source polarity must be maintained to turn on the MOSFETS (Vgs is plus for N-MOSFETS and minus for P-MOSFETS). Also you must never exceed the maximum Vgs rating (typically ±20V for most MOSFETS).
    bug13 likes this.
