Hey all. I would like to know if anybody has a circuit for a bicycle light powered by a coil/magnet. One that doesn't blink. As simple as possible. 200 ohm coil puts out about 3.6 volts Thanks in advance.
It will light 4 LEDs at 25ma each, max. That help?
I'm not using a dynamo. A single coil with magnet(s).
So far with 3 magnets, I don't feel any drag. I am trying to get away from batteries.I think you should try your LED's powered by a battery first. Putting less than 1/2 watt into the LED's will not produce very much light. I gave up on a cheap bike headlight for that reason.
The headlight I ended up building drives the LED's with up to 12 watts. At 2 watts I have to ride at low speeds because of the limited site distance of the dim light.
Be warned that your legs are generating all the power to light the headlight. I chose batteries, rather than a generator, to power the headlight both to relieve the legs and to keep the mechanics simple.
Interesting idea.The only thing simpler I could imagine is using the LEDs as the bridge rectifiers.
I think some current limiting (resistors) will be needed to prevent over-current to the LEDs.
