http://forum.allaboutcircuits.com/showthread.php?t=45277
this was my previous thread
Hi guys i have set up my bicycle generator
and what i'm currently doing is linking up the dc output of my generator straight to a voltmeter
the rating for my generator
Voltage 24V
Output Power 300W
No load current 1.8 Loaded current 16A
loaded speed 2750rpm no load speed 3400 rpm
efficiency 77%
what ive done now is basically linking the output of generator to my voltmeter and when cycling im able to get around 17-20+ volt
What i understand is that you need a sort of circuit to calculate the current and in return get the power.
If i were to directly connect an ammeter to my generator output and connect my voltmeter together would i be able to get a power rating?
do you guys have a simple circuit that involves a light bulb? the wattage that i get does not actually matter. I just want to be able to get the power output.
I'm using a laser tachometer to analyse the speed of tyre and the generator itself.
Voltage 24V
Output Power 300W
efficiency 77%
