Seems to be a communication misunderstanding? The important part of Ramusson's circuit re this discussion is AFTER the gate, and uses two resistors and the LED.Ramusson's solution uses an active device, and hence isn't a suitable counter for the claim that it can't be done without using an active device. I don't know what circuit you had in mind as you mentioned four resistors. So I couldn't very well ask someone to indicate why a circuit that wasn't actually given wouldn't work without the addition of an active device.
It's deja vu all over again. Guess you didn't see my post #23.Here is a bone-simple way to have the bi-color LED's illuminate in alternate states
I don't understand anymore what i should choose,
when i use the circuit with the relay, someone said that this is a shame because the relay would cost so much
whith the passive circuit with only resistors i will have to much power dissipation in the resistors?
what should i do?
Okay, so it would appear that our constraints are wanting to power 16 LEDs with a supply that can deliver a max of 600mA at 12VDC. Is it safe to assume that the aux connectors will ONLY be powering the LED circuits and nothing else?yes lets make a resume:
i have four alarmpanels, each alarm panel is located in a different building and will be working separately from each other.
on each panel i need to connect 2 remote panels with each 12 leds, one of the four panels wil controll two remote panels with each 16 leds.
on the aux connectors of the alarmpanel I have 12VDC 600mA
the remote panels will be placed at a distance of about 25 to 50meters away from the alarmpanel and i would like to connect them with a multicalble SVV 16x0,8
This is the post I was referring to:I have never spoken of 24V power supply, that was only suggested in some of the given circuits. I have only 12VDC available at the alarmpanel
