Biasing a piezo electric ceramic sensor
Discussion in 'General Electronics Chat' started by jateeq, Aug 25, 2014.
  1. jateeq
    Aug 25, 2014
    6
    I have a piezo electric sensor who's output is around +- 900mVpp. I want to bias this voltage around an operating point of 2.5V so I can reliably read it using one of the Arduino analog inputs (these inputs can read 0-5V with a 10 bit resolution).
    I've tried connecting 2.5V in series with the sensor, but everytime I do that the output is always zero (instead of 2.5V + sensor output). Does anyone know what I'm doing wrong?
    This is the sensor I'm using: http://www.sensortech.ca/site/index.cfm?DSP=Page&ID=120
    Thanks,
    Jay
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    the piezo sensor is non conductive, it will be a little more difficult adding bias. possibly an op amp to set the dc level.
  3. kubeek
    Sep 20, 2005
    4,689
    806
    I would connect a capacitor to the output of the piezeo, then a high-ish value resistive divider to provide bias and then straight to the adc. Putting DC straight on the piezo will most likely cause a large excursion and prevent it from operating properly.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    why put a cap in series? the piezo is a cap.
  5. kubeek
    Sep 20, 2005
    4,689
    806
    If I remeber correctly a DC voltage present across the piezo will cause it to remain in flexed position, which might prevent the sensor from operating correctly.
  6. jateeq
    Aug 25, 2014
    6
    Like this?
  7. jateeq
    Aug 25, 2014
    6
    @alfacliff: Would you mind telling me more about using opamps to set the dc level? I've only ever used them to amplify a signal or as voltage followers.
    Jay
  8. kubeek
    Sep 20, 2005
    4,689
    806
    Yes like that, what is the frequency of the signal?
  9. jateeq
    Aug 25, 2014
    6
    The signal is between 2-10 Hz
  10. kubeek
    Sep 20, 2005
    4,689
    806
    Then I´d try something like 1uF and 2x220k, to get the corner frequency low enough.
  11. RichardO
    May 4, 2013
    1,341
    429
    I suspect that the limiting factor for the bandwidth is the capacitance of the transducer. For Piezo buzzers this is usually 0.01 uF. He may need an FET or voltage follower to get the low frequencies he needs into the Arduino.
    This is what his data sheet gives.
    Charge Constant d31 -100 10-12 C/N
    Unfortunately, I don't know what this means. Does anyone else>
  12. lydia jin
    Aug 24, 2014
    I am a arduino hobbist, and I usually buy the components in icstation.com.
  13. ScottWang
    Aug 23, 2012
    4,932
    777
    Do you want to use an inverting op amp to amplify the input signal and set the gain to 2.77 or 2.78.
    gain=2.5V/900mV=2.777.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    A piezo element is a poor choice for 2 Hz, and still poor at 10 Hz.
    You said you are getting +/- 900mV peak to peak? Was that test done at 2- 10 Hz? If so, please ignore my comment. :)
  15. jateeq
    Aug 25, 2014
    6
    Thanks kubeek, the decoupling capacitor works!
    The output is much attenuated though, so I'm guessing my frequency is below cutoff still.
  16. kubeek
    Sep 20, 2005
    4,689
    806
    Then you can try going higher with the resistors. What kind of input signal are you measuring?
  17. jateeq
    Aug 25, 2014
    6
    The piezo measures changes in strain, so I measure a constant signal if the piezo is stretched at a constant rate, a large positive signal if it is applied a large strain in one direction, and a negative signal if it is strained in the other direction.
    I realized that treating this signal as ac will result in losing info when applying a constant strain per second (zero output). The output frequency depends on how quickly the piezo is being strained, which is why I said 2-10 Hz.
    Perhaps I shouldn't be high passing like I am right now, I should be low passing with the cutoff set to a decade above 10 Hz.
  18. kubeek
    Sep 20, 2005
    4,689
    806
    Then I suggest you change your setup alltogether. You will need a -5V supply to supply an opamp buffer, which will be connected directly to the piezo. After the buffer use a second opamp to level shift the signal and if necessary amplify it and send it into your ADC.
