Biasing a Class AB with a transistor
Discussion in 'The Projects Forum' started by bennyq, Apr 14, 2015.
  1. bennyq
    Sep 13, 2014
    6
    Hi, Im trying to design a Class AB power gain stage with the following circuit. Im having trouble with achieving a load of 8ohms(5vpp).. I would like the transistor to bias the current gain stage as I would eventually like to place a darlington pair package that has a VBE on of 1V.. Can I achieve that with this circuit? Or should I consider trying to use diodes..
      File size:
      7.9 KB
      42
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    That circuit is a mess.
    That is not how a transistor bias works.
    Google a transistor bias and post a reasonable result. We can work from there. Your circuit is not a reasonable starting point for a discussion.
    Start near the bottom of this one
    http://en.m.wikipedia.org/wiki/Bipolar_transistor_biasing
  3. bennyq
    Sep 13, 2014
    6
    Well this is my initial design, I'd want 1v preferably at the bases for turn on so voltage, 0.7V is a bit low. Is this design better?
      File size:
      12.8 KB
      34
  4. JDT
    Feb 12, 2009
    658
    85
    Your second circuit is a simpler way (and not so good) of controlling the quiescent current in the output transistors. There are a few other things wrong as well but I will leave that for now!
    Take your drive capacitor to the junction of D2 and base of Q2. Use another 100uF capacitor to bypass the 2 series diodes. Will work but won't produce full output swing as the transistors run out of drive current as the voltage across the 1K resistors gets low.
