Bi-polar step motor driver with MOSFETs
Discussion in 'The Projects Forum' started by nerdegutta, Feb 4, 2012.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,564
    805
    So I got inspired by the recent bi polar steppermotor drivers on the forum (this and this), using the TB6560 step motor driver. I search around, and found this on ebay.
    http://www.ebay.com/itm/Bipolar-Stepper-Motor-Driver-Kit-12A-60V-MOSFET-K158-/180660089974
    A bit more searching, and I found a schematic. I tried to make my own, and now I need some comments.
    The thought is that step and directions are controlled by signals applied to JP1.
    Will this work?
    I see now that I need decoupling caps on the IC's.
    Any comments are welcome, as long as they are constructive. :)
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What version of Eagle are you using?
    It looks pretty much like K158, except you have Q7 and Q8 upside down (drain and gate swapped) - if you built it like that, they would seem ON all of the time due to the body diodes.
    http://www.kitsrus.com/pdf/k158.pdf
  3. nerdegutta
    Dec 15, 2009
    2,564
    805
    I got Eagle 5.7.0, Hobbyist Licence.
    That's the schematic I found.
    So if I turn Q7 and Q8 it will be ok?
  4. stirling
    Member
    Mar 11, 2010
    52
    Might do but personally I wouldn't have hard wired the opto cathodes to gnd. This means you have no choice but to source current from your indexer/PC/whatever and if it can't source enough you'll miss steps. If you brought the optocoupler cathodes out to jumpers as well, you could choose source/sink. I prefer sink with a PC parallel port - but that's just me.
    [/QUOTE]
  5. nerdegutta
    Dec 15, 2009
    2,564
    805
    OK, good thinking. Adding a jumper should be easy.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Will you use a PC for controlling this? In any case I would have made arrangement so that you can have the controlling device compleatly isolated from the motor controller. This can be done by not having the LEDs in the optocouplers sharing the ground with the rest of the board. But using the ground form the controlling device.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You need a ground below R5. Compare that circuit to the one below.
  8. PaulEE
    Member
    Dec 23, 2011
    423
    32
    The one below is not below :)
  9. nerdegutta
    Dec 15, 2009
    2,564
    805
    I will be using a PC, and this software.
    http://linuxcnc.org/
    Ah, I missed that one. Thanks.
    It's strange how you can see, check and update a schematic, and still overlook something...
    I've added jumpers to the octo's ground. With these I can wire ground to either PC, or the PCB. Will that work?
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, that is not good.
    Connect the output transistors' emitters back to ground and remove the jumpers.
    It is the IR emitters (LEDs) on the input side of the optocouplers that needs to be grounded at the controlling PC.
  11. nerdegutta
    Dec 15, 2009
    2,564
    805
    Like this?
  12. stirling
    Member
    Mar 11, 2010
    52
    No - not like that. You've joined the cathodes - you need them separate if you want to follow my first suggestion AND the other's about grounding.
  13. nerdegutta
    Dec 15, 2009
    2,564
    805
    OK... I try again...
  14. stirling
    Member
    Mar 11, 2010
    52
    Nope. Like this
  15. nerdegutta
    Dec 15, 2009
    2,564
    805
    Oh... Thanks.
    Better now?
  16. stirling
    Member
    Mar 11, 2010
    52
    from the point of view of what I was getting at yes - but don't forget what other's have been saying though.
  17. t06afre
    May 11, 2009
    5,939
    1,222
    yes it looks OK. What you also could do. Is to add a schmitt trigger after optos and before the 4030N circuit. But this not strictly needed. Also check if your prallell port is 5 volt or 3.3 volt type output. What is your planned current draw to the LEDs in the optos
  18. nerdegutta
    Dec 15, 2009
    2,564
    805
    Do you think R1 and R2 are too big?
  19. Paul Kerry
    Member
    Jan 9, 2012
    36
    I agree with t06afre, the LEDs in the optos may not have enough current through them to turn the transistor on.
    The datasheet quotes 10mA current flow and a forward voltage of 1.18V to light the LED.
    If your parallel port has a 5 volt output you will need a a current limiting resistor of :-
    (5V - 1.18V)
    0.01A
    3.82V
    ------ = 382Ω The nearest preferred value is 390Ω
    0.01A
    If your parallel port has a 3.3 volt output you will need a a current limiting resistor of :-
    (3.3V - 1.18V)
    0.01A
    2.12V
    ------ = 212Ω The nearest preferred value is 220Ω
    0.01A
    I could be wrong with the nearest preferred value, but I believe the maths is sound. Please shoot me down in flames if I'm wrong ;)
    Cheers
    Paul
  20. nerdegutta
    Dec 15, 2009
    2,564
    805
    I got the same values as you did, so now I'm going to check the motherboard port.
    Thanks. :)
