Bi-directional k-bus to CAN
Discussion in 'The Projects Forum' started by poops, Aug 2, 2009.
  1. poops
    Aug 2, 2009
    I am trying to adapt k-bus 10-12V signal and put the constituent TxD, Rxd
    through a Max232 and then a PIC18F2XX. MY Final Goal is to convert K-bus to CAN_H and _L. Up to now, I figured I should use something like a 'single ended bus transceiver' AT6812b, or SI9243AEY to break apart the K-bus into Txd and Rxd. I think I must be missing something obvious though since these aren't easy to find bits. Can I push the K-bus all the way though the Max232 and on into the PIC, or do these devices require the symmetry of signal processing I think they do. The application is Automotive.
    Thank you
  2. poops
    Aug 2, 2009
    I found a nice bridge in a Dalllas Maxim DS2480B, its a little pricey though.
    Onward
