bgi problem
Discussion in 'Programmer's Corner' started by isha, Jun 4, 2006.
  1. isha
    Thread Starter Active Member
    Sep 16, 2005
    36
    in c++ program when i include graphics.h
    compiler give error
    "BGI is not supported under windows "
    please help me in removing this error .
    thanks
  2. n9352527
    Oct 14, 2005
    1,198
    That is basically what it means. If you code for any windows OS, then you can't use BGI. BGI is only valid for DOS environment. There is no way to remove the error or use BGI if you don't switch your code to DOS.
