Better alternative to DS1307
Discussion in 'General Electronics Chat' started by stoopkid, Mar 8, 2012.
  1. stoopkid
    Mar 3, 2011
    136
    I'm using a DS1307 with my arduino and the RTClib library. It works fine but I'm not particularly happy with the accuracy. It's losing at least 10 seconds a day. It may be because I'm testing it on a breadboard, but I would be happier seeing a bit less time loss than that.
    I know it's asking a lot, but I was hoping for better accuracy (nothing specific, just good for a clock) without paying more than a few dollars, and remains easy to interface with the arduino. I read that a chronodot is really good but they seem to be something like ten dollars.
    Just looking for suggestions... Thanks
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    The DS3231 is very accurate with its integrated crystal.
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
    Testing the DS1307 on a breadboard is likely to add sufficient stray capacitance to slow down the XTAL. You should be ok on a properly laid out pcb.
  4. stoopkid
    Mar 3, 2011
    136
    The MC34063A is a bit more than I wanted to spend but I'll check it out for more specialized projects. I figured the breadboard had something to do with it. Thanks guys.
