Best wire crimps for screw terminals?
Discussion in 'General Electronics Chat' started by jamus, Jun 18, 2014.
  1. jamus
    Feb 11, 2013
    54
    I use a lot of terminal blocks. I would like to get something to crimp on the ends of my wires so that they don't get frayed. Anyone know what product I should use?
    Edit: Never mind, I think I found what I need. "Wire ferrules"
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,297
    That's it. Basically, a ring terminal with the ring cut off. AMP, Panduit, Molex, etc.
    ak
  3. shortbus
    Sep 30, 2009
    4,096
    1,690
    I've always just stripped and tinned(soldered) the exposed wire.
  4. djsfantasi
    Apr 11, 2010
    2,905
    878
    Depending on the wire gauge, I've soldered the wires to header pins, and insulated the join with shrink tubing.
  5. djsfantasi
    Apr 11, 2010
    2,905
    878
    Depending on the wire gauge, I've soldered the wires to header pins and insulated the soldered connection with shrink tubing. For heavier wires, I've also covered the joint with silicon sealer or hot glue.
    I've found that the spacing on the terminal blocks match the header pins.
    Look at the lower right in this image.
  6. somlioy
    Member
    Jul 28, 2010
    22
    Wire (or end) ferrules is what you need. Make sure to get a proper tool aswell.
    djsfantasi likes this.
  7. KJ6EAD
    Apr 30, 2011
    1,426
    364
