Best way to supply 10amps to 2 motors?
Discussion in 'The Projects Forum' started by bzzzt, Dec 22, 2010.
  1. bzzzt
    Nov 1, 2010
    Hi all,
    I am trying to build a circuit which synchronizes the position of two motors, each of which will need to be supplied 10 amps. Is there such a motor driver that would drive 10 amps to two brushless DC motors? I also want it to be able to plug it into a wall as normal ( I would convert the AC to DC with a transformer and diodes).
    Thanks :D!
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    There are many BLDC driver circuits around. What do you mean by "synchronize" the two motors? Same speed?
  3. #12
    Nov 30, 2010
    16,665
    7,313
    No single device can synchronize two motors unless the single device is a chain between the gears on the motor shafts. You have to "sense" the positions of each motor and use a second driver so either motor can be nudged until it catches up. It really is not a simple thing to do.
  4. windoze killa
    Feb 23, 2006
    605
    24
    Not quite true.
    You can use servo positioning, a slotted wheel or some other type of position or speed sense and alter the drive to each motor. Quite easy really.
