I have a switching power supply which I cannot find any information on (it's a Yokogawa PS003B-0101)
It has a 10 pin connector, but a more general question is what is the best way of determining what each pin is on any PSU?
The problem is, I think with most PSUs, two of these pins need to be shorted for the power supply to actually turn on but how would you know which two it is? What is the best way of determining this without a datasheet for example? I'm sure shorting pins willy nilly is not wise and I'm not very good at reverse engineering so I'm having a hard time trying to figure it out from the board itself.
