Best way to choose filter capacitor
Discussion in 'General Electronics Chat' started by fastwalker, Oct 10, 2009.
  1. fastwalker
    Thread Starter Active Member
    Jun 24, 2009
    38
    Hi All,
    I'm trying to measure the current drawn by a DC motor using a shunt. This particular motor has onboard power electronics that allow you to control it's speed. When I measure the voltage across the shunt I see it's quite a noisy signal. See http://resplendid.com/Vshunt Bank 1 pump 8 only running.jpg for a scope trace picture.
    To get a more steady signal my plan is to put a filter capacitor across the power lines to the motor. What is the way to choose the most suitable value for the cap? And what type of caps work best in this application (e.g. electrolytics, greencaps, ceramics). Note that I do not have a spectrum analyzer handy so haven't checked what the signal looks like in the freq. domain yet.
    Thanks for any help,
    FW
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It would be a lot easier to just use a low-pass RC filter across your shunt. The capacitors would be much smaller.
    Did you see my reply to your other thread?
