Best Way to Alert Myself
Discussion in 'General Electronics Chat' started by peroa, Jan 5, 2010.
  1. peroa
    Jan 5, 2010
    I'm trying to find the best way to alert myself electronically on my wrist.
    I've looked into a small vibrator, although that would work, I am also looking into shocking myself, not a painful shock but enough to feel it.
    What components could be used to create a feelable shock and what kind of power source would be required to do this?
  2. Paulo540
    Member
    Nov 23, 2009
    188
    Alert yourself to what?
    Cell phones have alarms, mine has an appointment book.
  3. peroa
    Jan 5, 2010
    Haha, that's very true but it's for an experiment and must be through the touch sense. :)
  4. Paulo540
    Member
    Nov 23, 2009
    188
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    How about making a resistor hot pad. Can be very gentle and without any startle reflex. Shock and even vibrators can give startle, which you might not want in an experiment.
    John
  6. peroa
    Jan 5, 2010
    A hot pad is an interesting idea but it needs to be intermittent; kind of like a pulse for a short period of time.
    I don't know the type of input yet, I'm just trying to find components and ways of doing this. And specifically, I'm trying to get more info about how to create a small but noticeable shock.
    Thanks a lot though for the info!
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    It would help a lot, if you would give a little more information about your plans and needs. In particular how do you define "short period of time?"
    John
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I suspect he wants to "alert" unsuspecting friends.:eek:
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We are quite adamant about safety around here. We try to help our electronic n00bs avoid situations that might lead to injury or property damage, which includes self-inflicted electric shock. This is in accordance with the rules and code of board conduct.
    Instead of electric shock, consider using a vibrating pager motor, or perhaps a small relay or solenoid. Any of these three could be easily actuated with a low voltage supply, and would give audible as well as tactile (touch) input - along with being quite safe.
  10. boriz
    Jul 16, 2009
    48
    Mild electric shocks are easy. See: <snip>
    But as a mechanical alternative, here’s an idea: Strip a cheap earpiece, the in-ear type you get with personal stereos. It functions very much like a solenoid. By giving it ‘kicks’ from say 3v, you should be able to feel it if the diaphragm is pressed against your skin. If it’s too gentle, up the voltage. Just make sure the kicks are very short, otherwise you’ll burn out the coil, and maybe a bit of skin too.
  11. Paulo540
    Member
    Nov 23, 2009
    188
    Ruh-roh...
  12. jpanhalt
    Jan 18, 2008
    5,699
    909
    This forum tries to avoid stun guns in accord with its rules of conduct:
    Providing a link to stun guns is the same as providing that information. That is the main reason I suggested a non-shock notification and asked for more information. It seems the OP really just wants a device to shock. No device for shocking can be made perfectly safe.
    John
